IOS for 1841
LucaSalvatore_2
I have an 1841 which has an ADSL WIC installed and also a VPN module.
Having trouble finding an IOS that supports both the ADSL WIC and VPN.
Currently got c1841-adventerprisek9-mz.124-25b.bin on there but this does not seem to support the ADSL WIC as i get these errors and the ATM interface does not show up;
CFG-3-CARD_NOT_SUPPORTED: Slot 0: Unknown WAN daughter card, Part# 73-9932-6, HW-Rev 8.0, Board-Rev A0
Router#sh ip int bri
FastEthernet0/0 unassigned YES NVRAM administratively down down
FastEthernet0/1 192.168.1.4 YES DHCP up up
however this image does support the VPN
Cisco 1841 (revision 7.0) with 234496K/27648K bytes of memory.
Processor board ID FHK12102A30
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
The ip_base image supports the ADSL but not the VPN....
Anyone know of an IOS that supports both?
thanks
I have also tried c1841-entservicesk9 and c1841-advipservicesk9-mz
Both support the VPN but not the ADSL module... Any help would be greatly appreciated!
9 Replies 9
ohassairi
Level 5
Level 5
Giuseppe Larosa
Hello Luca,
I would say 12.4T advanced enteprise take one of the late ones like 12.4(20)T
check with FN as explained in other post
Hope to help
Giuseppe
Leo Laohoo
Can you provide the exact product ID of the card?
I dont have that at the moment but i found an IOS last night that worked.
Hi Luca
Can U tell me what ios you used?
I have the same problem tried several ios but none appreciate me
thanks
I used;
c1841-adventerprisek9-mz.124-24.T2
Mohamed Sobair
Level 7
Level 7
The bellow image should support both:
c1841-advsecurityk9-mz.124-15.T7.bin
However, If you check the feature Navigator, you will find out that the (Advance Enterprise services) does supports both also. I am wondering why your hardware couldnt identify the ADSL WIC, keep in mind the WIC could be faulty.
Mohamed
thanks
ADSL iz working but router didn;t identify vpn module thats why ia have t find suitebale ios or I have to upgrade routers ram
thanks
Mohamed Sobair
Level 7
Level 7
You dont have to upgrade the router ram.
You have a sufficient DRAM of 256 which is compatible with the required IOS. Try the IOS I have sent earlier.
Mohamed
