Spanning Tree between Cisco and ALU Switches
Oct 28th, 2009
Bit off topic.
I'm getting a unusual spanning-tree behaviour between a Cisco 3560 and a ALU 6850 switch.
I have rapid spanning tree set up on the ALU and Rapid-pvst on the Cisco. A few vlan's configured across a dot1q trunk.
The ALU is set with the lowest bridge priority, however both switches on all vlan's see them selves as root. With no change in the priority field.
It appears that 802.1w and Rapid-PVST are not compatible in this instance?
Any ideas? config samples if you have done this before.
Thanks in advanced
Overall Rating: 4 (1 ratings)
simontibbitts Wed, 10/28/2009 - 01:52
  • Silver, 250 points or more
Hi Gareth
Correct, rapid-pvst is Cisco proprietary. You should see the correct root bridge on vlan 1 but not on the other vlans
Your best solution is MST if both sides support it
Simon
gareth.orley Wed, 10/28/2009 - 01:57
Thanks Simon
Been playing with it the last hour.
Funny enough, when you place a redundant link in the mix, no changes on the bridge root, but the cisco does block the ports to stop the loop.
If any body else has any ideas, would be much appreciated.
simontibbitts Wed, 10/28/2009 - 03:23
Hi Gareth.
That is because rapid-pvst+ uses the Cisco Shared Spanning Tree (SSTP) multicast mac 01-00-0C-CC-CC-CD for it's BPDUs on all VLANs besides VLAN 1. The non Cisco switches flood these and that is how the Cisco switches learn of a loop condition
Simon
