Unable to Connect to Cicso Aironet 1250
Oct 28th, 2009
My office just bought the Cisco Aironet 1250 and I am task to set it up. Right now, I am unable to connect to AP even when it is configured as Open Authentication without encryption. Tried using both laptops and our products to no avail. The same laptops and products are able to connect to other wireless routers So far, only my Linksys Wireless-G USB network Adapter is able to detect it.
We are very puzzled by this because we are able to setup and connect to it initially. But when we try to reconfigure it to another setting, everything starts to fail. We have tried doing factory default.
The AP is connect only to a Windows 2003 Server running DHCP and IAS. Appreciate if someone can help me on this. Thanks
jeromehenry_2 Wed, 10/28/2009 - 04:39
  • Silver, 250 points or more
Can you post your AP configuration?
Without it, it is difficult to know why it is failing.
BTW, do you broadcast the SSID (if you do show run, do you see "guest-mode" under the dot11 ssid section?
Jerome
Leo Laohoo Wed, 10/28/2009 - 16:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Basic Wireless LAN Connection Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008055c39a.shtml
Hope this helps.
