Unity Connection 7.x Platform Incompatibility
Oct 28th, 2009
I need your help regarding a new installation of Unity Connection 7.x.
I have the MCS7825H4-K9-UCB1 server and it came with UC 7.1.2a software.
While installing the server I upgraded it to 7.1.2.21900-5 (7.1.2aSU1)
Now I am getting Platform Incompatibility while booting. And then, I have to press continue to proceed. The server seems to work ok after that... but if anyone restart it he has to access it with a screen and keyboard and press "Continue" to proceed!!!!
Using the CLI command "show hardware" I got the following:
admin:show hardware
HW Platform : UNKNOWN
Processors : UNKNOWN
Type : UNKNOWN
CPU Speed : UNKNOWN
Memory : UNKNOWN MBytes
Object ID : UNKNOWN
OS Version : UNKNOWN
Serial Number : UNKNOWN
RAID Version :
BIOS Information :
RAID Details :
No RAID status found.
I cannot go back to the 7.1.2a because the upgrade was applied during installation.
Based on the compatibility information below the server should be compatible
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/data_sheet_c78-491743.html
Is it a bug on the software used? Can you suggest me a healthy one?
