RVS4000 empty incoming table
Oct 28th, 2009
Hi all,
has anyone experienced the problem of having the incoming table log empty? I can get entries on the outgoing table but the incoming is always empty. I'm running the latest firmware and I tried everything I could but I don't get one single entry on the incoming table.
Any feedback is appreciated.
Best regards,
Gianluca
David Carr Wed, 10/28/2009 - 07:34
  • Silver, 250 points or more
Are you using this as an endpoint firewall or is it behind some other device that is being used as a firewall?  Are you using the intrusion protection and if so what signature?  I am trying to get a feel for what exactly you have setup on the router.
gianluca.colangelo Wed, 10/28/2009 - 07:51
Hi David,
I use no intrusion protection and no other device used as a firewall.
Gianluca
David Carr Fri, 10/30/2009 - 08:15
As to why it is not receiving any logs with the current firmware, I am uncertain of why your not seeing any logs.  If you would like you can call the SBSC at 866-606-1866 and see if they can further troubleshoot with you and help you fix this issue.
Te-Kai Liu Mon, 11/02/2009 - 10:10
  • Gold, 750 points or more
Do you have port forwarding or remote management enabled on the RVS4000? If so, you should see the incoming sessions get logged in the Incoming Table.
