Unable to access LAN from VPN Client
Answered Question
Oct 28th, 2009
I have configured an 877 for VPN Client access. The Client authenticates and connects and gets an IP address off the IP pool. However, it cannot access anything on the IP network.
I've included my router's config. The VPN Client is v5.0.05.0290.
Any ideas as to what I am missing?
Correct Answer by vincent.monnier about 7 years 4 months ago
Can you try to revers our Client-VPN ACL, I think it's writen in the wrong way
For exemple :
ip access-list extended Client-VPN
remark *** permit Client VPN pool ***
permit ip any 192.168.201.0 0.0.0.255
or more accurate
permit ip 192.168.1..0 255.255.255.0 192.168.201.0 0.0.0.255
Overall Rating: 5 (1 ratings)
vincent.monnier Wed, 10/28/2009 - 04:55
I thinks it's a firewall (ACL) issue.
Once the IPSec packets have been decrypted, they are passing through the ACL configure on the External interface.
You should add a "permit ip 192.168.201.0 0.0.0.255 192.168.1.0 0.0.0.255" at the begin of the ACL [ext-ACL-IN] protecting the WAN interface .
slmansfield Wed, 10/28/2009 - 06:23
  • Silver, 250 points or more
I'm wondering if ext-ACL-IN should also allow esp traffic.
clark-computers Wed, 10/28/2009 - 07:28
I have put in a statement permit esp in. Here is the output of show ip access-list ext-ACL-IN:
Extended IP access list ext-ACL-IN
5 permit ip 192.168.201.0 0.0.0.255 192.168.1.0 0.0.0.255
10 deny tcp any any log fragments
20 deny udp any any log fragments
30 deny icmp any any log fragments
40 deny ip any any log fragments
50 deny ip any any option any-options
60 deny ip any any ttl lt 3
70 deny ip host 0.0.0.0 any
80 deny ip 127.0.0.0 0.255.255.255 any
90 deny ip 192.0.2.0 0.0.0.255 any
100 deny ip 224.0.0.0 31.255.255.255 any
110 deny ip 10.0.0.0 0.255.255.255 any
120 deny ip 172.16.0.0 0.15.255.255 any
130 deny ip 192.168.0.0 0.0.255.255 any
140 permit udp any eq domain any (3330 matches)
150 permit udp any eq ntp any (1700 matches)
160 permit udp any any eq isakmp (774 matches)
170 permit udp any any eq non500-isakmp (347 matches)
180 permit esp any any
190 permit icmp any any time-exceeded
200 permit icmp any any unreachable (159 matches)
210 permit icmp any any echo-reply
220 permit tcp any any established (87522 matches)
230 deny ip any any (1471 matches)
Also, attached is an output of the VPN client's route table: before and then after a connection is established.
slmansfield Wed, 10/28/2009 - 09:09
Can you verify that the devices on your internal network have a route to the address pool used by the VPN client?
clark-computers Thu, 10/29/2009 - 02:47
I can confirm that this is the case. In fact, the router with the VPN Client config is the LAN default gateway as well.
Correct Answer
vincent.monnier Thu, 10/29/2009 - 03:29
For exemple :
or more accurate
