Kenneth Mohammed Wed, 10/28/2009 - 05:12
  • Silver, 250 points or more
If you are using a full blown version of CUCM, this is controlled on the DN confiugration page under external mask section, but you can only put numbers in this field.
If you are using CUCME, then this field can be changed under the ephone-dn configuration using the "description" command.
Hope that helped, if so please rate.
