IOS upgrade for WS-C3750-48PS-S
ali.alghamdi
I would like to know the Cisco product number for IOS upgrade for WS-C3750-48PS-S to WS-C3750-48PS-E which should upgrade the box from IP Base to IP Services. If possible, how much is does it cost.
Hi Ali.
I believe you need CD-3750-EMI=
Dan.
7 Replies 7
Reza Sharifi
Hi Ali,
For pricing on the IOS upgrade, you should talk to your sales rep, as different companies (depending on how much you buy) get different discount percentage.
Reza
Thanks Reza,
I still need the product number though!
Hi Ali.
Dan.
Ali,
You need an activation key
Here is the part number:
3750E48-AISK9LCBQ Advanced IP Services for 3750 E 48 ports, upgrade from Base
Check with your sales rep to make sure this is what you need.
Reza
Reza,
It looks to me to be an activation key for Cat3750E. The original post specifically mentions 3750 switch. Do you think it's the same?
As Dan posted earlier:
CD-3750-EMI= Enhanced Multilayer Image upgrade for 3750 FE models
HTH, Ingolf
INGOLF,
You and Dan are correct. I thought this was an E series box. Sorry and Thanks for clarification
Reza
Thanks Iyde for the clarification.
