Access ASDM from a different vlan and interface than the management
billetj01
Hello everybody,
I am a new user of an ASA5510 using ASA version 8.0 and ASDM 6.0(2)
That firewall is used to be the central part of a network be multiple inside VLANs and Internet connection.
So my firewall is directly connected to a switch 3750 and couple of other swicthes are connected to that first switch.
At the moment, in order to connect to ASDM I have on cable in trunk between eth1 of the firewall and eth0/1 of my switch (so set as trunk line) and one cable between the management interface and eth0/48 of my switch on a specific VLAN (VLAN 69 on my switch which is just for the management interface). At the moment it is the only workaround I have found to connect to that ASDM. So basically I have one comnputer on the network on VLAN69 from which I can get the ASDM working. But all my switch have are on Vlan 1 for management purpose, so I need another computer on vlan 1 to manage my switches.
I am almost sure that there is a way to be able from Vlan1 to access to ASDM but I don't find how.
Here is my configuration of the ASA5510 :
ASA Version 8.0(2)
hostname AFAW001
domain-name test.COM
enable password xxxxxxxx encrypted
names
name 10.3.72.10 Switch01
name 10.3.72.37 AdminPC
dns-guard
interface Ethernet0/0
nameif Internet
security-level 0
ip address 62.xxx.xxx.x81 255.255.255.xxx
interface Ethernet0/1
nameif Inside_Network
security-level 100
no ip address
interface Ethernet0/1.1
vlan 1
nameif VLAN_Admin
security-level 100
ip address 10.3.72.1 255.255.255.128
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 10.3.74.241 255.255.255.240
passwd h83ErV7OnuCAO8TG encrypted
boot system disk0:/asa802-k8.bin
ftp mode passive
clock timezone EEST 2
clock summer-time EEDT recurring last Sun Mar 3:00 last Sun Oct 4:00
dns server-group DefaultDNS
same-security-traffic permit inter-interface
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu Internet 1500
mtu Inside_Network 1500
mtu VLAN_Admin 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
asdm history enable
arp timeout 14400
nat-control
global (Internet) 101 interface
nat (management) 101 0.0.0.0 0.0.0.0
nat (VLAN_Admin) 101 0.0.0.0 0.0.0.0
route Internet 0.0.0.0 0.0.0.0 62.xxx.xxx.x81 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.3.72.0 255.255.255.128 VLAN_Admin
http 10.3.74.240 255.255.255.240 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh 10.3.74.242 255.255.255.255 management
ssh 10.3.72.37 255.255.255.255 VLAN_Admin
ssh timeout 5
console timeout 0
dhcpd address 10.3.74.242-10.3.74.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b71e78a98adb84b4f0a5d544be20e21c
: end
Thank you for your help
JB
12 Replies 12
Collin Clark
JB-
Are you required to trunk? There is only one VLAN on it, so for simplicity sake, you make want to remove the trunk and have it connect as an access port. Under interface Ethernet0/1 you should remove the security level. Other than that your config looks good. When on VLAN1, can you SSH into the ASA? Ping it? Anything in the log?
Sorry, I have forgot to let some "..." to show where I have cut in my config. I have about 20 vlans in my configuration with dhcp enable and NAT. All the VLAN I have hidden are subcontractors which are sharing the same internet access. So I need that trunk.
When I am on VLAN1 at the moment I can not do anything to the ASA, no ping, no ssh, nothing.
Do you see your IP in the ARP table of the ASA?
Intersting, it is not in the ARP table of the ASA.
Here is the actual config of the ASA :
ASA Version 8.0(2)
hostname AFAW001
enable password h83ErV7OnuCAO8TG encrypted
names
dns-guard
nameif Internet
security-level 0
ip address 62.xxx.xxx.x82 255.255.255.xxx
security-level 0
no ip address
vlan 1
nameif VLAN_Admin
security-level 100
interface Ethernet0/1.10
vlan 10
nameif VLAN_Visitor
security-level 30
ip address 10.3.72.129 255.255.255.128
...... (VLANs)
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
passwd xxxxxxxxx encrypted
ftp mode passive
domain-name OL3.AREVA.COM
pager lines 24
logging enable
mtu management 1500
mtu Internet 1500
mtu VLAN_Admin 1500
no failover
asdm history enable
arp timeout 14400
nat-control
nat (VLAN_Visitor) 101 0.0.0.0 0.0.0.0
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.3.72.130-10.3.72.254 VLAN_Visitor
dhcpd dns 212.86.0.5 212.86.0.6 interface VLAN_Visitor
dhcpd enable VLAN_Visitor
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
Cryptochecksum:2aa198c41a4b426d33a3d4fd097818c2
: end
and the result of show route on the ASA :
Gateway of last resort is 62.xxx.xxx.x81 to network 0.0.0.0
C 10.3.72.0 255.255.255.128 is directly connected, VLAN_Admin
C 10.3.74.240 255.255.255.240 is directly connected, management
C 10.3.72.128 255.255.255.128 is directly connected, VLAN_Visitor
C 62.xxx.xxx.x80 255.255.255.xxx is directly connected, Internet
S* 0.0.0.0 0.0.0.0 [1/0] via 62.xxx.xxx.x81, Internet
If you don't see your MAC in the ARP table, there is a layer1/2 problem. You'll need to make sure your PC has the correct IP address (10.3.72.x), your in the correct VLAN (1), and the VLAN is on the trunk. Also you may want to remove the nameif on the main interface.
no nameif Inside_Network
If you use subinterfaces, you typically do not also want the physical interface to pass traffic, because the physical interface passes untagged packets. This property is also true for the active physical interface in a redundant interface pair. Because the physical or redundant interface must be enabled for the subinterface to pass traffic, ensure that the physical or redundant interface does not pass traffic by leaving out the nameif command. If you want to let the physical or redundant interface pass untagged packets, you can configure the nameif command as usual. The firewall could be moving the packets to the wrong interface because the main interface and E0/1.1 are both processing vlan 1 packets.
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/intrface.html#wp1044006
Status :
no nameif
no security-level
no ip address
IP address of the computer in VLAN Admin correct :10.3.72.37 255.255.255.128 GW 10.3.72.1
And maybe could help the config of the 1st switch :
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname ASWE0001
enable secret 5 xxxxx
username root privilege 15 password 7 xxxxx
no aaa new-model
clock timezone CST -2
clock summer-time HEL recurring
switch 1 provision ws-c3750-48ts
no ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name xxxxx
errdisable recovery cause psecure-violation
errdisable recovery interval 120
no file verify auto
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
interface FastEthernet1/0/1
description linktoFirewall
switchport mode trunk
udld port aggressive
interface FastEthernet1/0/2
description To S
switchport access vlan xx
switchport mode access
no mdix auto
no cdp enable
spanning-tree portfast
interface GigabitEthernet1/0/1
description LinkToBuilding C
interface GigabitEthernet1/0/2
description LinktoBuilding F
interface GigabitEthernet1/0/3
description LinkToBuilding B
interface GigabitEthernet1/0/4
description LinkToBuilding Q
interface Vlan1
ip address 10.3.72.10 255.255.255.128
ip default-gateway 10.3.72.1
ip classless
no ip http server
ip http authentication local
no ip http secure-server
access-list 99 permit any log
snmp-server community public RO
snmp-server community SubC RW
control-plane
alias exec sis sh inter status
alias exec s sh ru
line con 0
logging synchronous
line vty 0 4
access-class 99 in
exec-timeout 0 0
logging synchronous
login local
transport input ssh
line vty 5 15
no login
no exec
end
So far no communictaion and still nothing in the ARP table, not even the switches. Really strange.
It is strange. Can you do a show interface trunk and make sure VLAN 1 is on it? In the ASA do you see the MAC/IP in the ARP table? You may have to ping the switch from the ASA first.
Sorry for the delayed answer.
So on the switch, here is the answer from show interface trunk :
show interfaces trunk
Port Mode Encapsulation Status Native vlan
Fa1/0/1 on 802.1q trunking 1
Gi1/0/1 on 802.1q trunking 1
Gi1/0/2 on 802.1q trunking 1
Gi1/0/3 on 802.1q trunking 1
Gi1/0/4 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa1/0/1 1-4094
Gi1/0/1 1-4094
Gi1/0/2 1-4094
Gi1/0/3 1-4094
Gi1/0/4 1-4094
Port Vlans allowed and active in management domain
Fa1/0/1 1,4,10,30-47,50,69,371-372
Gi1/0/1 1,4,10,30-47,50,69,371-372
Gi1/0/2 1,4,10,30-47,50,69,371-372
Gi1/0/3 1,4,10,30-47,50,69,371-372
Gi1/0/4 1,4,10,30-47,50,69,371-372
Port Vlans in spanning tree forwarding state and not pruned
And still no ARP table entries for the switches. i've tried to put it as a static arp but nothing better.
If I remember, when There was a name on the main interface (Inside) I had the switch entries but tagged as being from the global interface, not the VLAN_Admin interface.
Do you see the MAC address of the PC on the switch port it is connected too? Can post the results?
show mac address-table interface fastEthernet 0/1
Ok, result of the command on the switch port where my PC on VLAN_Admin is connected :
Mac Address Table
Vlan Mac Address Type Ports
1 0012.7959.716e DYNAMIC Fa0/1
Total Mac Addresses for this criterion: 1
On the same switch, I have the PC which is on the management VLAN, and that one appears in the ASA arp Table.
Great. Looking at the management protocols you have configured.
Is your IP in this range? Do you use SSH or ASDM?
The IP address of the computer on the VLAN_Admin is 10.3.72.37, mask 255.255.255.128, GW 10.3.72.1
At the moment I am trying with ssh, faster to test. Then if I succeed to have the ssh traffic going across, I think the https will be easy for ASDM.
