IOS NAT Load Balancing w/ Failover Problem
exonetinf1nity
Greetings, i am currently using the configuration below to provide failover between two DSL connections, all is working fine but i had expected outbound connections to be load balanced between the two DSL links on a round robin basis, however looking at the nat translations shows that only one of the links is being used, failover on the other hand works without issue.
track 1 ip sla 1 reachability
interface FastEthernet0/0
ip address 10.50.1.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface FastEthernet0/1
ip address 192.168.1.6 255.255.255.0
ip nat inside
interface Dialer0
description WAN Interface
mtu 1492
ip address **********
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
interface Dialer1
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 2
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 212.74.102.15 track 1
ip route 0.0.0.0 0.0.0.0 213.246.177.200 10
ip nat translation timeout 2
ip nat translation tcp-timeout 2
ip nat translation udp-timeout 2
ip nat translation icmp-timeout 2
ip nat inside source route-map opal interface Dialer1 overload oer
ip nat inside source route-map pipex interface Dialer0 overload oer
ip access-list extended dynamicNat
permit ip 10.50.1.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 any
deny ip any any
ip sla 1
icmp-echo 212.74.102.15
frequency 5
ip sla schedule 1 life forever start-time now
route-map opal permit 10
match ip address dynamicNat
set ip next-hop 213.246.177.200
route-map pipex permit 10
set ip next-hop verify-availability 212.74.102.15 1 track 1
Any assistance would be much appreciated.
exonetinf1nity
Think ive solved it by changing the preferance on the static routes from:
to
This does now appear to be working ask expected however the default gateway is showing as 213.246.177.200. I would have thought that 212.74.102.15 would take preferances even though they have the same metric.
Could i ask if anyone has had experience with a similar configuration?
Thank you for this post man ! this have been so useful. I experienced almost the same problem the router was load balancing well, but the failover was not occuring well between both equal default route.
After using those command: ip nat translation timeout for tcp icmp and udp all the system has worked propertly.  yeah you need a Big bottle of Jack Daniel  :)    the funniest thing behind is that help me 5 years After......................!!!!
