AIR-BR1310G-E-K9, error: cannot associate: No response
jerome.gimbert
Hi Guys,
I have to do a wireless bridge with 2 AIR-BR1310G-E-K9. I configure 1 AP root bridge and 1 AP non-root bridge, with the same SSID.
But on the AP non-root bridge, the interface dot11 radio don't change it state to up and give this error: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response.
I don't why it doesn't work. Even if i try a configuration which it already work on a site, it doesn't work to.
So I ask to me if there is a problem with internal antenna?
If I configure the 2 AP to access point role with 2 different ssid, I can see the 2 ssid but with a weak signal.
This AP can work without external antennas?
Thanks for your help
jerome.gimbert
Sorry but the exact reference is AIR-BR1310G-E-K9-R, and it seems to need externa antennas ...
Sorry to say, but if the part number contains "-R', external antennas are required. There is no internal antenna in that unit.
This brings back (painful) memories of first ordering 1300s. I had a very similar experience. :(
