Wireless Bridge error with AIR-BR1310G-E-K9,cannot associate: No response
Oct 28th, 2009
Hi Guys,
I have to do a wireless bridge with 2 AIR-BR1310G-E-K9. I configure 1 AP root bridge and 1 AP non-root bridge, with the same SSID.
But on the AP non-root bridge, the interface dot11 radio don't change it state to up and give this error: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response.
I don't why it doesn't work. Even if i try a configuration which it already work on a site, it doesn't work to.
So I ask to me if there is a problem with internal antenna?
If I configure the 2 AP to access point role with 2 different ssid, I can see the 2 ssid but with a weak signal.
This AP can work without external antennas?
Thanks for your help
jeromehenry_2 Wed, 10/28/2009 - 07:44
Hi Jerome,
The 1310 definitely can work with the internal antenna but... is the AP mounted somewhere? Some mounting options imply an external antenna as they position the internal antenna toward the wall...
jerome.gimbert Wed, 10/28/2009 - 07:47
Sorry but the exact reference is AIR-BR1310G-E-K9-R, and it seems to need externa antennas ...
jeromehenry_2 Wed, 10/28/2009 - 08:12
Oops, yes, R... so yes, you know now why it does not work, you don't have an internal antenna on this one.
