ASA SSL VPN Help Customization
Oct 28th, 2009
ASA 5520 (8.2.1), ASDM (6.2)
I'd like to put my own help info in the the right hand pane where the normal Cisco help appears on the Terminal Servers page.
Is this possible? I tried using the Help Customization via the SSL configuration ASDM (6.2) with no luck.
b-mcdonald Thu, 10/29/2009 - 11:12
I've tried those steps via the CLI & the ASDM and both methods do not work.
Do you have any other ideas?
