10-28-2009 07:33 AM
Have 2 users outside of my WAN that get e-mail using smtp. Mail server is Microsoft Exchange and clients are using Microsoft Outlook. When I forward port 23 to the Spam & Virus Blocker, the users are no longer able to connect to the mail server (smtp.domain.com). What setting am I overlooking?
Solved! Go to Solution.
11-04-2009 07:18 PM
Thanks to everyone who replied.
Think there was a little confusion on what I was trying to accomplish. Needed for a user to get to his e-mail remotely using Microsoft Outlook, just as if you were checking your personal Comcast, AT&T, etc. account from home.
Short version is that the Cisco Spam & Virus Blocker does not support users outside of the network (lan, wan, etc.). This leaves no way for a user working remotely to connect to the Mx server and login. Was able to bypass the problem with the following solution.
Forward port 25 to Spam Blocker from the firewall
Forward alternate port 2525 to internal port 25 pointed to my mail server.
Works like a charm and the Spam blocker is still able to filter the e-mail before the remote user downloads it to his inbox.
10-28-2009 07:45 AM
Are you trying to telnet to the Blocker?
10-28-2009 07:51 AM
From the client side, just trying to login to the mail server. When I forward port 23, Outlook returns a message saying it cannot connect to the mail server. Users on the local network are unaffected.
10-28-2009 08:14 AM
When you say the are trying to login to the mail sever, are they trying to access a mail box or access the server interface itself? And are you trying to accomplish a telnet session to your mail server by forwarding port 23 to it?
10-28-2009 01:35 PM
They are trying to connect to a mailbox and send / receive messages. Telnet does not enter the equation at all.
10-28-2009 02:19 PM
Are they connecting via a NATed IP Address or DNS Name?
Are you changing the Firewall to redirect the port 23 by changing the NATed Public IP Address?
If they are usiing the DNS then thier Outlook may be trying to connect to Virus Blocker instead of theExchange Server when you change the port forwarding so you will need to add a second DNS NATed Address or have them connect via the NATed IP Address directly.
10-29-2009 05:41 AM
If they are trying to connect externally to your mail server and you have all mail going to the blocker you will need to setup SMTP Authenication on the blocker. If you need assistance I would recommend calling Small Business support 866-606-1866.
11-04-2009 07:18 PM
11-04-2009 07:35 PM
I finnaly looked at my original post......kept saying I had forwarded port 23 instead of 25. No wonder I had everyone confused
. Thanks again for the help everyone.11-05-2009 06:46 AM
No Problem Glad you were able to get everything working.
Brian
