UCCX 7 Supervisor Web Interface
Answered Question
Oct 28th, 2009
Hi Everyone,
We will be upgrading our UC environment beg 1st quarter 2010. I've read that supervisors will have the ability to modify agents' skills which is something my contact center managers have been griping they need to be able to do. I'm just concerned about how MUCH they will be able to do or UNdo from the interface. I'm hoping they cannot access Applications in particular. I was wondering if anyone could be so kind as to post a screen shot of the Supervisor web page so I can get a visual of what they will have access to. As always, thanks in advance!
Kelly
Correct Answer by bsugamele1 about 7 years 6 months ago
Kelly, the new supervisor login works very well. You can set access for Supervisors to only be able to modify skills for their teams or all teams. Screenshot attached.
Overall Rating: 4 (4 ratings)
Correct Answer
bsugamele1 Wed, 10/28/2009 - 09:38
Jonathan Schulenberg Wed, 10/28/2009 - 18:52
  • Cisco Designated VIP,
    2017 IP Telephony
I'm not sure I would be quite that enthusiastic about this. The interface is not perfect. For example, the last time I checked the CSQ Name field is editable to supervisors.
I don't know about you but I can certainly see a supervisor wanting to rename a CSQ to something else to suit their mood.
When I turn this on for customers I am always careful to stress caution.
shaheeramunir Wed, 10/28/2009 - 20:45
Is there any audit report present to show which Supervisor changed the CSQ of an agent or renamed it?
Jonathan Schulenberg Thu, 10/29/2009 - 08:24
    2017 IP Telephony
No there is not.
andrei.goncalves Fri, 05/28/2010 - 07:54
Hi there !
Can you tell me how can I access directly this page ?
I'd like to make a test to check if it's possible give access to the supervisors.
Thanks.
Andrei.
Gabriel Saavedra Fri, 05/28/2010 - 09:07
  • Silver, 250 points or more
Hi Andrei,
You can access this the same as when you as an administrator access.
http:///appadmin
The username will be the supervisor ID and the password de supervisor password.
Gabriel.
andrei.goncalves Fri, 05/28/2010 - 09:12
I tryied that but It's not what I expected, because the supervisor can download the Hitorical Reports and I'm working on remove the default reports and customize them.
In the real-time reporting it's possible to see all UCCX resources and statistics.. and I have more than one application.
Thanks again.
Andrei.
