wr mem gives error on ACE module
Oct 28th, 2009
I am not able to save the configuration on the ACE module.
Admin# wr mem
Generating configuration....
Error in generating running config..copy aborted
"Write memory failed for context Admin"
Any help would be appriated.
sachinga.hcl Wed, 10/28/2009 - 14:52
Hi Neha,
Kindly check the current system resource usage for each context by entering the #show resource usage
command .
If the resource usage percentage is high, the ACE is overloaded .
Use the copy running-config startup-config command instead of the write memory command. May be it can solve your issue for now.
Write back if it does not sovle your issue.
Sachin Garg
