10-28-2009 08:10 AM - edited 03-06-2019 08:21 AM
Is there a command I can run to see the total backplane throughput in use on Cisco Cat4006 Switches ?
10-28-2009 08:17 AM
Hello CCDE,
if IOS based
try with
sh platform health
in this lenghtly show there is a section about BW usage per slot
example
sh platform health | begin Allocation
Allocation ceiling Current allocation
kbytes % in use kbytes % in use
Linecard 1's Store 258.00 3% 9.92 100%
Linecard 2's Store 258.00 62% 162.09 100%
Linecard 3's Store 258.00 62% 162.09 100%
Linecard 4's Store 258.00 66% 171.03 100%
Linecard 5's Store 258.00 62% 162.09 100%
Linecard 6's Store 258.00 62% 162.09 100%
Hope to help
Giuseppe
10-28-2009 08:22 AM
Do we know what the max througput is per slot for 4006.I could not find data sheets.It says total of 30Gbps backplane throughput
10-28-2009 09:30 AM
Hello CCDE,
a WS-4548 can do only 6 Gbps per slot also on a C4506 ( to be said)
So I would expect 6 Gbps per slot
Hope to help
Giuseppe
10-28-2009 11:53 PM
Hi.
The maximum throughput in Cat4x00 series of switches is actually determined by the Supervisor used, and they are fixes at 6 Gbps per slot for all non-E supervisors, while the Sup6E gives 24 Gbps per slot in Cat4500E chassis.
HTH, Ingolf
10-28-2009 09:39 AM
If catos , the current usuage is shown with "show traffic" . If you need the total then you would have to look up the specs on the box on cisco.com .
10-28-2009 09:52 AM
"show traffic" gives me nothing
