How to make IOS complete command in CLI
Answered Question
Oct 28th, 2009
In Juniper OS if I do "ip ro" then I press <tab>, the command automatically the complete command appears as "ip route". How can I do that in Cisco IOS?
Correct Answer by Edison Ortiz about 7 years 6 months ago
It's the same in Cisco IOS.
The problem with 'ip ro' and tab is that there are multiple options.
Rack1R1(config)#ip ro?
route routing
So how the router will know which to choose on a tab?
Now, if you type
Rack1R1(config)#ip routi
Rack1R1(config)#ip routing
The second line was completed with the tab as there is only one option for 'ip routi'.
Edison
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Wed, 10/28/2009 - 09:18
  • Hall of Fame,
    Founding Member
route routing
Now, if you type
Edison
Reza Sharifi Wed, 10/28/2009 - 09:37
  • Cisco Designated VIP,
    2017 LAN
Marlon,
You mean space bar or the tab key?
In JUNOS, when you type sh and press the space bar key, it will complete the command for you. Now, you can do the same thing with the tab key, but why would you want do that when space bar can easily do for you.
As for Cisco IOS, the space bar does NOT complete the command and if you want to completed the command you have to use the tab key
Reza
news2010a Wed, 10/28/2009 - 11:14
Sorry. I meant JunOS.
I recalled I tried in the Cisco IOS before and that did not work - probably the IOS version was old and it did not offer that feature.
Thanks folks!
iyde Wed, 10/28/2009 - 15:04
  • Silver, 250 points or more
Hi Marlon.
Either it has been an ambiguous command as described by Edison, or it would have been a veeeeeeeeeery old IOS :-)
HTH, Ingolf
Leo Laohoo Wed, 10/28/2009 - 16:13
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Enterasys also completes a command with the use of the spacebar.
