10-28-2009 09:24 AM - edited 03-15-2019 08:16 PM
I have a CME with voip dial-peers to a 2600 router. The 2600 has a frame-relay wan connectivity with vofr dial-peers to the far-end. Not sure if the 2600 will complete the call end-to-end going from voip h323 dial-peer to a vofr dial-peer. The far-end has a 2600 with pots dial-peer to a PBX.
10-28-2009 11:33 AM
No, it will not complete the call, because you cannot have call with one end VoFR and other VoIP.
Either convert to VoIP end-to-eend, or you will have to go thorough a POTS interface.
10-28-2009 11:42 AM
Thanks, for the info. So if I put an E-1 interface in the CME connected to the 2600 and use pots dial-peers from the CME to 2600 via the E-1 the call will complete at this point.
10-28-2009 03:17 PM
Yes it will, but it's expensive as it requires physical ports and DSPs. So VoIP end-to-end is often preferred.
Please remember to rate useful posts with the scrollbox below.
