ASA 5510 HTTPS Access
Oct 28th, 2009
Hello
I've upgraded my ASA 5510 to Version 8, and also the ASDM to 621. When I try to access via HTTPS I get "401 Unauthorized". The config looks fine, so I'm presuming it could be because IE7 possible. Any help would be great.
Overall Rating: 5 (6 ratings)
Jatin Katyal Wed, 10/28/2009 - 12:44
  • Cisco Employee,
Please check your running config and see if you have this command:
ssl certificate-authentication
interface management port 443
Please remove it and then try to access it again.
JK
Plz rate helpful posts-
