ACE Module Reverse Proxy with URL rewrite
Oct 28th, 2009
Hi All,
Try to configure ACE as reverse proxy for WebLogic server farm. But have a issue on Rewriting URL.
http://172.16.36.100/test1/ -> http://192.168.1.20:8080/test1/ This is Possible.
But, http://172.16.36.100/test1/ -> http://192.168.1.20:8080/test2/
T tried this with redirection server farm. redirection works but the cannot see the pages wich coming after the /test1/xxxxxxxxx.xxxx and redirection can experiance the client since URL change on browser.
Is there a any other logic?
Have anyone tried this before?
Vira
virajmendis Wed, 10/28/2009 - 20:05
Yes, I tried with %p variable. It's not work.
But the datasheet said HTTP header manipulation is possible with ACE. This feature support only with SSL?
Thanks…..
Gilles Dufour Fri, 10/30/2009 - 03:53
you can manipulate the header...not the url.
Everything after the url can be modified, removed, added...
So if your server sends a redirect, you can intercept it and change the Location: header.
But again, you can't change the url.
Gilles.
