3640 in boot loop..wont boot up..says Insufficient memory to load image
Oct 28th, 2009
I have a cisco 3640 router which is in a constant boot loop..it wont boot up. I formatted the flash and copied the correct image ?(through another 3640) but it didnt help..after decompressing the file it gave the following error...
Not sure what to do in this case..Can someone help please???/ Thanks....
Ethernet/IEEE 802.3 interface(s)
2 FastEthernet/IEEE 802.3 interface(s)
4 ATM network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Read/Write)
16384K bytes of processor board PCMCIA Slot1 flash (Read/Write)
snmp-server enable traps tty
% Invalid input detected at '^' marker.
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
glen.grant Wed, 10/28/2009 - 11:11
You need to get a smaller image , you do not have enough dram to support the image.
uzmausmani Wed, 10/28/2009 - 11:17
But it used to have this image only on it before...anyways I'll try a smaller image..
uzmausmani Wed, 10/28/2009 - 13:21
thanks..it worked...Is the larger image going to be supported if I alter the IOmem size??
glen.grant Wed, 10/28/2009 - 16:12
You have to look at the system requirements when you download it from CCO. It will tell you the "minimum" requirements needed for dram and flash. Changing IOM is not likely to help. The show version command tells you how much dram and flash you have in the box and compare that to the system requirements.
