10-28-2009 12:09 PM - edited 03-06-2019 08:21 AM
I currently have a 6500 with a Sup 720 3B. I want to add a second Sup 720 3B for redundancy. I want to minimize the disruption the devices that are currently connected to this 6500. Is adding the redundant Sup as simple as just plugging it in and it will sync up with the current Sup. Will there be any disruption to my currently connected devices? (I already have the appropriate SSO redundancy statements on the 6500, ready to go.) Thanks for any advice you can offer.
Solved! Go to Solution.
10-29-2009 09:33 AM
Jerry,
Good point. I have got some redundant sup-720-3C, lately and they all come with native IOS version, mostly SXI. So, I guess it depends on how old the sup is right?
Reza
10-29-2009 12:04 PM
Okay, assuming the new SUP is native IOS also. It is better off to go into the new SUP to make sure it boot from the CF. The reason is the default boot variable might point to the sup-bootdisk instead of disk0, if this is the case, the box might be in standby cold, and you will have to manually copy and reload the standby/new SUP. The way I posted before is you will go into ROMMON and force it to boot from disk0, and you know what is on disk0 (matching the IOS version on you active one). This way, it will be in standby hot when it comes up.
If your new one is not in native mode, you will have to convert it. I can't think of a way to convert it without taking the box down since you don't have spare chassis.
jerry
10-28-2009 01:19 PM
Hi Jay,
Adding a second Sup-720 should not affect anything, but I would still open an outage window just in case. Just make sure the second Sup is exactly the same as the first one (hardware and software) and since you already have SSO redundancy ready, you should be good to go.
Reza
10-29-2009 06:08 AM
Reza,
Thanks for your response. I have another, what may be, elementary question. How do I know what software is on my new Sup? I do not have a spare 6500 in which I can install the Sup and determine the software version. There is a small yellow sticker on the module that states:
CATOS min sw req is 8.3.7
IOS min sw req is unchanged 12.2(17d)SXB1
If the software version of the new Sup is different than the existing Sup will the software be automatically copied from the existing Sup to the new Sup? Is this just a "plug and play" install?
10-29-2009 08:01 AM
Jay,
The IOS image will not get copied from master to slave. You have to do it manually to disk0: and slavedisk0:
If you don't have another box to see the ver, then put it in as a second sup and
Use the following command to copy a file to the bootflash: device on a redundant RP:
Router# copy source_device:source_filename slavebootflash:target_filename
Good luck
Reza
10-29-2009 08:19 AM
My only concern is if the new SUP720-3B in in hybrid mode. If it is native, and if you have spare CF card with the same image as your other SUP, then you can do the following step.
1. Insert the new SUP and connect the console cable into the new SUP
2. Do Ctrl+Break and go into ROMMON
3. Boot the new SUP from disk0:
4. Once it is up, you can copy image and you don't even need to reboot and the software is 100% compatible
jerry
10-29-2009 11:57 AM
Jerry,
I am in native mode. Can I just do this:
I have a spare CF card and will make sure that it has the same image as my currently installed Sup Module.
I will insert the new, redundant Sup module. The redundant Sup module will come up in "Standby Hot" mode.
Then, I'm done. Is it this simple?
Thanks for your help.
10-29-2009 12:04 PM
jerry
10-29-2009 08:58 AM
The software image will be downloaded unto the 2nd sup720s from the 1st. It should be plug and play. However, be prepared if something goes wrong.
regards,
Victor
10-29-2009 09:33 AM
Jerry,
Reza
10-29-2009 09:37 AM
Yes, it is depend on what is on the original SUP and the new SUP. If it is on native, you should be fine with the sequence I've listed before.
jerry
10-29-2009 09:35 AM
If it is native IOS, it will not download from active from the new one.
jerry
