NAC with 6509
Answered Question
Oct 28th, 2009
Hi All,
I've setup mac-notif on 6509 chassis, but it doesn't send mac-notif to the NAC. in agent, I got:
"OOB Error; connected device MAC not found".
here is config of 6509:
snmp-server community privatecw121! RW
snmp-server community publiccw121! RO
snmp-server trap-source Vlan5
snmp-server enable traps snmp linkdown
snmp-server enable traps MAC-Notification move threshold
snmp-server host 192.168.12.250 publiccw121!
any suggestion would be appreciated. it's kind of urgent.
thanks
Alex
Correct Answer by Faisal Sehbai about 7 years 3 months ago
Alex,
The routing table on the CAS is kept in this file /proc/click/real_routing_table/table
cat that file and you'll see what the table is like.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
alex goshtaei Thu, 10/29/2009 - 10:22
Hi Faisal,
sorry to bugging you alot. my problem has been resolved with Switch. But I have another one.
I type "dhclient" on CAS by mistake, not I lost connection to CAS. it is remote and don't have access to it.
how can I access again to CAS?
thanks man
Alex
Faisal Sehbai Thu, 10/29/2009 - 13:13
Alex,
If you have it in HA, you might be able to get to it from that other CAS from it's ETH2 or ETH3 interface, otherwise your only option is to find out what IP address it got and connect to it through SSH/HTTPS.
HTH,
Faisal
alex goshtaei Thu, 10/29/2009 - 13:25
thanks Faisal,
finally i have someone to connect to console port and fixed it.
I notice when I add static route to CAS through GUI, then run the command "route" in CAS, it doesn't show that static route. is it normal? do I need to enter static route through CLI instead of GUI?
thanks alot
Alex
Correct Answer
Faisal Sehbai Thu, 10/29/2009 - 13:35
Alex,
HTH,
Faisal
alex goshtaei Thu, 10/29/2009 - 13:46
thanks Faisal,
thanks alot
Alex
