show policy-map interface help understanding the output table
Oct 28th, 2009
I've attached 2 examples of the output from a "show policy-map interface xxx n/n" I want to understand the table that is at the bottom of the output. I have some routers that do not show the table when I issue the command but for the ones that do, what am I looking at? everything to me is clear until I get to the table that shows 8 classes, 0-7 and rsvp information. What are the 8 classes? are these generic CS buckets? what? I have machines using more than one AF class that show only one row of class 0 in the table (also attached).
I cannot find a table explanation on the CCO, only definitions for everything preceding it.
shouldn't the numbers be sums from the classes? they're not.
Thanks in advance.
Giuseppe Larosa Wed, 10/28/2009 - 14:49
  • Hall of Fame,
    Founding Member
Hello Nelson,
if you mean these lines:
>> class Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
0 891548776/488485052793 0/0 0/0 20 40 1/10
1 0/0 0/0 0/0 22 40 1/10
2 0/0 0/0 0/0 24 40 1/10
these are related to WRED weighted random detect
WRED is a congestion management tecnique that tries to prevent to have full queue that causes generalized tail drops.
Hope to help
Giuseppe
