WLAN 4402 for Radius Authentication
Answered Question
Oct 28th, 2009
Hi Guys,
Please help me on how I can set-up my WLAN controller 4402 for Radius authentication, if you have links or procedures that you can share, that will be very much appreciated. :-)
Thanks in advance.
Correct Answer by Peter Nugent about 7 years 8 months ago
It depends if you are using Cisco ACS or Windows IAS. The controller config is the same but the RADIUS side is different.
Also what are you trying to configure, managemment users, PEAP etc via RADIUS
PEAP via ACS is here
http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a00807917aa.shtml
PEAP via IAS is here
http://www.cisco.com/en/US/partner/products/ps6366/products_configuration_example09186a0080921f67.shtml
Hope that helps
Overall Rating: 5 (1 ratings)
Correct Answer
Peter Nugent Wed, 10/28/2009 - 14:18
  • Cisco Employee,
Hope that helps
gagamboy15 Sun, 11/01/2009 - 07:43
Thanks for the link, that would be a great help. :-)
