Vlan Running Config fetch failed
Answered Question
Oct 28th, 2009
I have this msg when i try to archive the config file from all the device (1400 devices) :
VLAN RUNNING Config fetch failed....VLAN Config fetch is not supported usinf TFTP.
I'm reading some topics about. I don't known why it doesn't work.
I'am trying manualy to copy the vlan.dat from a device to LMS with TFTP. To do that, i have created an empty vlan.dat file on /tftpboot. It works fine.
This directory have a permission of 777 for root and other.
Attached the dcmaservice.log
It seems LMS can't create a new temporary file to /tftpboot. Rgards
Correct Answer by Joe Clarke about 7 years 7 months ago
LMS uses the routing table to find the appropriate local server address. However, this can be overridden on a per-device basis by editing the RME ID under RME > Devices > Device Management > RME Devices > Edit Device Attributes.
Overall Rating: 5 (1 ratings)
hlichiere Wed, 10/28/2009 - 14:20
Oups...I'm tied.
You are right. It's a secondary address. Where can i change it. Thx
Correct Answer
Joe Clarke Wed, 10/28/2009 - 15:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
