525 handsets and Edit Dial softkey
Answered Question
Oct 28th, 2009
  • Bronze, 100 points or more
When our customer uses their EditDial softkey to return a missed or received call, the cursor put them at the end of the 10 digit number string ? Most handsets have the cursor at the start of the digits so they can simply press 9  and call from there.  With the cursor at the end, you have to back arrow to the beginning to add the leading 9 - what a pain !
Is there a way to adjust or modify this in the 525's settings?  I cannot seem to find any info on it in the 525 manual I have...
Thank you,
Stacy
Correct Answer by David Trad about 7 years 7 months ago
Just create the translation rules for this, it can not be done (Well not that i am aware of since the last answer i got) and everyone complains about it so i just gave up and create rules so that it auto inserts the number there, could never understand why this needed to be done, Cisco phone systems are the first ones i have seen where you have to manually edit the number to be able to call it back :D
Just PM me stacey if you need help with creating the Translation rules and would be more then happy to try and work with you on this.
Cheers,
David.
Overall Rating: 5 (1 ratings)
Correct Answer
David Trad Thu, 10/29/2009 - 01:13
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Cheers,
David.
stacy.thompson Thu, 10/29/2009 - 07:20
Thanks David!
I'll see if the Cisco BU team has a definitive "cisco" answer....and if I hear nothing then we'll do just as you suggested- edit the trans rules to add it for them.
I'm less impressed with the 525 each day.
Stacy
stacy.thompson Thu, 11/05/2009 - 08:55
No one else has offered any input here- 1) is this normal for a 525 ?  2) how do you fix it short of taking Davi'd suggestions ?
Thx,
Stacy
Steven Smith Thu, 11/05/2009 - 08:57
I will put in a request to have the edit dial changed, but it might be awhile before that gets implemented.
