Can't access the Unity version 5.0 System Admin Page
Oct 28th, 2009
Randomly we can't access Unity admin page. Restarting IIS service fixes the issue. The only document I was able to find is Failure to Access the Unity System Admin Page
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00805552da.shtml#NetPro
which is provided for Unity 4.x and does not offer a permanent solution.
Any assistance will be greatly appreciated.
Yefim
Jaime Valencia Wed, 10/28/2009 - 14:59
Maybe you're having the same issue as this one:
IP Telephony: Unity 5.0 SA admin page keeps hanging
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd406d2
You may also search NetPro for the same problem and how it was solved.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
y-sapozhnikov Thu, 10/29/2009 - 07:59
Thanks for your reply.
We will apply the latest ES to fix it.
Could not rate using the link provided
got Forbidden File or Application.
Yefim
Hoan Mai Wed, 10/28/2009 - 15:59
There are a few fixes in 5.0, make sure you patch the latest ES -
You're most likely hitting this defect.
CSCsg76524 BusinessLogicManagerSvr.dll violates DLLMain rules and causes deadlock
y-sapozhnikov Thu, 10/29/2009 - 08:01
Thanks for the info.
This bug is for 4.2.1 and we are running on 5.0.1 and always able to restart IIS.
We will apply the latest ES.
Yefim
