3750 as a router
Answered Question
Oct 28th, 2009
  • Purple, 4500 points or more
All,
I have a 3745 router that connects to our 3750 stack. The 3745 has 2 connections: a DS3 and a L2 connection across a MAN. My question is all theory, but if my 3745 were to die, shouldn't I theoretically be able to remove the L2 connection from the router, connect it to the 3750, configure it as a routed port, and then run my routing protocols over it? The MAN connection is configured as my failover link now between two routers, but I think this would work if I needed a quick connection in the event of a failed router.
John
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Hello John,
short answer yes.
using an SVI you could even be able to connect both the router and the 3750 to the MAN connection.
but this could have other side effects.
Hope to help
Giuseppe
Correct Answer by Edison Ortiz about 7 years 5 months ago
Yes.
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Wed, 10/28/2009 - 14:58
  • Hall of Fame,
    Founding Member
Yes.
John Blakley Wed, 10/28/2009 - 15:00
Thanks Edison. I thought so. :)
Correct Answer
Giuseppe Larosa Wed, 10/28/2009 - 14:59
  • Hall of Fame,
    Founding Member
Hello John,
short answer yes.
Hope to help
Giuseppe
