UT not discovering cameras connected to the network
jain.nitin
Level 3
Level 3
Hi All, I dont understand why UT is not discovering cameras connected to my access switches. There are aroung 300 cameras in the building but LMS not even finding one and also it discovered 20 hosts out of 250 end hosts. but IP phone it is finding correctly. anyone has any clue about this.
Please help
6 Replies 6
Joe Clarke
What version of Campus Manager do you have? Are any of the end hosts being acquired on the switch to which one of the missing cameras is connected? How are the switch ports configured? Are those switches properly managed in Campus Manager? What kind of switches are they? What version of code are they running? What version of SNMP are you using?
Dear Clarke, I am attaching snap shot of LMS app version along with acquisition report. LMS is detecting only few hosts in the network. It showing only 20 which it detected long time back since then it did not detect a single host. we are running SNMP version 3 in the network. we have 3750 switches in stack.they are running 12.2 35 SE image
here are the attachments
These don't answer all the questions.
Dear Clarke, there are 20 end host discovered by LMS which is on the same switch. we have all most 290 3750 switches stack in the network so LMS is just got end host discovery from one switch out of 290.
below is the switch port configuration for the switch from which LMS is discovering end hosts
interface GigabitEthernet1/0/6
switchport access vlan 200
switchport mode access
interface GigabitEthernet1/0/7
spanning-tree portfast
interface GigabitEthernet1/0/8
speed 1000
duplex full
interface GigabitEthernet1/0/9
speed 1000
duplex full
interface GigabitEthernet1/0/10
below is the switch port config for switch from which LMS is not getting end host information.
interface FastEthernet1/0/2
switchport access vlan 53
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
service-policy input IPPHONE+PC-ADVANCED
Yes all the switches are properly managed in the campus manager.
All switches are 3750 switches in stack.
They all are running 12.2(35) SE
we are using SNMP version 3
Okay, this is probably the problem. When using SNMPv3, you need to make sure the switches are configured for SNMPv3 contexts. Run the "show snmp context" command. For each VLAN context listed, you will need to configure something like:
snmp-server group GROUP v3 TYPE context VLAN read v1default
Where GROUP is your SNMPv3 group name, TYPE is one of auth or priv, and VLAN is the VLAN context from the "show snmp context" command. You will need to repeat this for EVERY VLAN context. Then run a new UT acquisition, and your end hosts should show up.
