CME7.1 Extension Mobility Timeout
Answered Question
I am working with CME7.1 and was trying to get an extended timeout before the phones log off the voice user profile and switch back to the logout profile.  I have issued the command "max-idle-time 9999" under the voice user-profile; however, it seems like the phone is still logging off overnight.  I am going to assume that it is timing out after 6 or 12 hrs.  Is there something else causing the users to log out besides the max-idle-time?  Essentially I would like it if the phones never automatically logged off unless they log in elsewhere, but would settle for a high idle timeout value.  Appreciate any advice or input.
Correct Answer by Marcos Hernandez about 7 years 3 months ago
Try this:
Router(config)# voice user-profile 1
Router(config-user-profile)# no max-idle-time
Router(config-user-profile)# reset
Also, something that you can check is this:
conf t
telephony-service
em logout time1 [time2] [time3] ---------> This command is supported in Cisco Unified
CME 4.3 and later versions. time-Time of day after which logged-in users are automatically
logged out from Extension Mobility. Range: 00:00 to 24:00 on a 24-hour clock
You can also disable this command: no em logout time1 [time2] [time3]
Marcos
Overall Rating: 5 (1 ratings)
Correct Answer
Marcos Hernandez Thu, 10/29/2009 - 05:56
Try this:
conf t
telephony-service
Marcos
Thank you for the reply.  I have actually origially used no max-idle-time which had resulted in the phones resetting during the night.  This is what prompted me to try the idle time of 9999 with the same result.  I haven't applied a em logout time (and believed the default was none).  Just a little more info, the IOS version is 12.4(24)T1.
