QOS on portchannel on 7609 routes
Oct 28th, 2009
Hi all
I am trying to have the following QOS parameters applied on a portchannel interface on my 7609 router.
I am getting the below mentioned error.Any suggestions in this regard will be appreciated.
class-map match-any cos7
match cos 7
class-map match-any cos6
match cos 6
class-map match-any cos1
match cos 1
class-map match-any cos0
match cos 0
class-map match-any cos4or5
match cos 4
match cos 5
class-map match-any cos2or3
match cos 2
match cos 3
policy-map AAV-downlink-child
class cos7
police 2000000
priority
queue-limit 128 packets
class cos6
bandwidth percent 36
class cos4or5
bandwidth percent 20
class cos2or3
bandwidth percent 15
class cos1
bandwidth percent 4
class cos0
bandwidth percent 4
queue-limit 1024 packets
policy-map AAV-downlink-50M
class class-default
shape average 50000000
service-policy AAV-downlink-child
interface Port-channel10
description LACP Group ID 1
ip address 10.41.193.129 255.255.255.252
no ip redirects
ip ospf cost 10
mls qos trust dscp
interface GigabitEthernet1/6
no ip address
mls qos trust dscp
channel-group 10 mode active
interface GigabitEthernet1/7
no ip address
mls qos trust dscp
Router(config-if)#int port-channel 10
Router(config-if)#service-policy output AAV-downlink-50M
shape average command is not supported in output direction for this interface
Configuration failed!
Router(config-if)#service-policy input AAV-downlink-50M
shape average command is not supported in input direction for this interface
Router(config-if)#
Kind regards
Ullas
Overall Rating: 4 (2 ratings)
Edison Ortiz Wed, 10/28/2009 - 16:19
  • Hall of Fame,
    Founding Member
Ullas,
You are facing a limitation on the hardware as regular line cards do not support egress shaping.
For shaping on egress, you need a WAN module (SIP/SPA or FlexWAN).
Edison.
ullasupendran Wed, 10/28/2009 - 16:46
HI edison
Dou you meant to say it wornt support ingress shaping too? it was not taking the service policy input also....
Ullas
Edison Ortiz Wed, 10/28/2009 - 17:33
  • Hall of Fame,
    Founding Member
You aren't allowed to shape on ingress even with a WAN module. Shaping can only be done on egress. However, you can police on ingress and egress with the regular line card.
Edison.
