Video conferencing configuration
Oct 28th, 2009
Greeting
can anyone advice about video conferencing with H.323 in catalyst env (catalyst 6500/3500)?
I have qos enabled, but, it is autoQoS only, I guess it is not including video conferencing, what I need added on top of auto QoS?
Any comments will be appreciated
Thanks in advance
Joseph W. Doherty Sat, 10/31/2009 - 05:38
If AutoQoS doesn't recognize your H.323 traffic, you'll need to add statements to the AutoQoS generated statemens to recognize and treat as desired your video stream. Assuming you already knew that, you can use a combination of the exisiting AutoQoS generated statements and Cisco QoS design guides on how "best" to configure for video conferencing.
For a design guide, you might start with:
https://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSIntro.html
https://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html
