Instalation and Configure E1
Oct 28th, 2009
hi everybody,
Today i tried to install an E1 for PSTN and then register in the Call Manager 5.1, but in the router (gateway of voice), it is not appears nothing and so my question is: do i need to put a special command to show me E1 controller?, i know when you put the E1 in the router this should appear E1 controller and then configure it, please correct me if I'm wrong. Please help me in this situation, thanks in advance.
Overall Rating: 4 (1 ratings)
James Hawkins Thu, 10/29/2009 - 03:23
  • Blue, 1500 points or more
To properly answer this question we need to know the exact hardware and IOS your are running.
You can use the "show inventory" and "show version" commands to gather this information.
In the absence of this data I will take a guess that you have a card that can act as either a T1 or an E1 (for example the VWIC2-1MFT-T1/E1). If this is true then you need to use the "card type e1" command followed by the slot and bay locations.
More details in the Command reference at the link below.
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_c1.html#wp1012287
Please rate if helpful.
