VPN on ASA 5510 Using Security context senairo
Oct 28th, 2009
Is this possible after enabling Security Context on ASA 5510 .
Will be able to allow Dedicatedly Vlan 5 Traffic (In Red Line) to use ISP-2 to communicate outer world and Vise versa if I enable Security Context in ASA 5510
Will be able to allow Dedicatedly Vlan 3 Traffic (In Blue Line) to use ISP-1 to communicate outer world and Vise versa.
Will be able to configure VPN when we enable Security Context on ASA 5510
Herbert Baerten Thu, 10/29/2009 - 00:18
To the first question(s): Yes, this separattion of traffic is precisely what security contexts are meant for, i.e. you will have 2 "virtual firewalls" each with their own (sub)interfaces and their own routing table.
To the second question: unfortunately no, you cannot configure VPN in multi-context mode (yet - this may be supported at some point in the future).
shridhar76 Thu, 10/29/2009 - 00:53
HI ,
If i am keeping router above on my ASA then can i do this or not.. Because some guys are telling that we can do.
Herbert Baerten Thu, 10/29/2009 - 01:23
You mean have a single router on the outside of the ASA?
Should be no problem, it just gets a bit more complex, i.e. you can either:
- configure a shared outside interface on the ASA, and PBR (Policy Based Routing) on the router (since you cannot route based on destination, you will need to route based on source address)
- keep the traffic totally separated by configuring VRF-lite on the router, so you get 2 virtual routers, each which its own (sub)interfaces and routing table (very similar to contexts on the ASA).
shridhar76 Thu, 10/29/2009 - 01:51
Can you please be more specific i have posted the Network Design with this Question.
Herbert Baerten Thu, 10/29/2009 - 02:09
Well, can you clarify your current question please? You wrote "If i am keeping router above on my ASA" but in your design there are 2 routers above the ASA...
shridhar76 Thu, 10/29/2009 - 02:23
Hi Buddy,
Okey here is my Question.
According to our requirements if i configure Security Context will i be able to do the following.
1. ISP 1 will be terminating on Router -A
2. ISP 2 will be terminating on Router -B
3. Traffic from VLAN 2 should use only ISP-2 to go out.
4. Traffic from VLAN 3 Should use only ISP-1 to go out.
3. will i be able to Tunnel VPN traffic in and out from ISP-1 and 2 to VLANand VLAN to ISP-1 and 2
If you need any more clarrifcation plz let me know
Thanks in Advance
