Multi Level Access
Oct 29th, 2009
I want to config the user with specific rights & privilges
I tried config in Sub user group & tried giving the roles, but then all rights are assigned to these users. But i need these user with limited access for writing & with Read only rights.Could you suggest how to customize the options with specific rights.
CUCM used is 7.1
Navin
Jaime Valencia Thu, 10/29/2009 - 07:02
You're on the right track, you need to create specific roles and then add them to user groups. Then start adding users.
If you add some of the ones predefined you'll get a lot of other permissions so you can create your own from scratch
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
