can ACL do this
Answered Question
Oct 29th, 2009
like fire policy,on the router or the switch,user can first define the application service,the when user define the ACL,can use the define-service.like this:
define app-service1 tcp= 1812,1813,udp=1813,1646
ip access extend test
permit ip host t1 host t2 service app-service1
permit ip host t3 service app-service1 host t4
Correct Answer by cameron.moody about 7 years 7 months ago
It sure can with object-groups
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_object_group_acl.html
eg object-group service myservices
tcp 1812
udp 1813
udp 1646
object-group network myservers
host 1.1.1.1
host 2.2.2.2
network 10.10.10.0 255.255.255.0
Hope this helps
Please rate if helpful
Overall Rating: 5 (3 ratings)
tachyon05 Mon, 11/16/2009 - 08:54
yes it can. however, i am running into issues with router crashing, as soon as i configure IPsec. in the link you provided, it does say "ipsec is not supported". i am just not sure if things will work if i only use IPsec on ACLs that have nothing to do with VPNs, and only use old style ACLs (without object groups) on ACLs that have anything to do with VPNs. Still trying ...
QFX527518 Mon, 11/23/2009 - 22:49
thx.our company device's IOS not support the object_ACL.only wait new device and new ios.
