Anyconnect Updates on console possible?
Oct 29th, 2009
when i try to connect with an older Anyconnect Linux client to our ASA, then the client automatically updates and logs in. Thats perfect so far.
But when i do not use the Anyconnect-GUI (vpnui) and try to connect on the console/cli instead without X, then it says:
>> notice Establishing VPN - Checking fur updates ...
>> state: Connecting
Then Anyconnect just hangs up. When i then update Anyconnect via GUI and go back to console, i successfully can log in again.
So just the update process obviously has a problem when not using the vpnui GUI.
Has anyone successfully updated the Anyconnect client via console?
Thanks in advance!
Marco
