7613 Temperature
Oct 29th, 2009
Hi everyone
Could you tell me about limited temperature?
Because, we are using 7613Router but when i issued command 'sh envi' , i did not understand enough about the message.
So, What is the recommend temperature in 7613 from Cisco and if the temperature go to upper than recommend rate what happend and how should it does?
One more thing, if it checked module #1, which one is the most thigs?
For example, it must check inlet temperature or outlet temperature? and what is the inlet/outlet ?
show environment
VTT 1:
VTT 1 OK: OK
VTT 1 outlet temperature: 29C
VTT 2:
VTT 2 OK: OK
VTT 2 outlet temperature: 33C
VTT 3:
VTT 3 OK: OK
VTT 3 outlet temperature: 31C
module 1:
module 1 power-output-fail: OK
module 1 outlet temperature: 44C
module 1 inlet temperature: 28C
module 1 device-1 temperature: 26C
module 1 device-2 temperature: 26C
module 2:
module 2 power-output-fail: OK
module 2 outlet temperature: 41C
module 2 inlet temperature: 27C
module 2 device-1 temperature: 25C
module 2 device-2 temperature: 26C
Please, explain for me ^^
Thank you!
