ASDM login ( ASA 5510 )
Oct 29th, 2009
Hi Gentlemen,
I m new to ASA FW. I just tried to configure the ASA FW by using the ASDM. But I cannot lauch the ASDM login page.
I did the following procedure b4 login to ASDM page https://192.168.1.1/admin
( 1 ) ciscoasa# dir
Directory of disk0:/
61 -rwx 14635008 12:43:34 Sep 04 2009 asa803-k8.bin
2 drwx 4096 12:47:24 Sep 04 2009 log
63 drwx 4096 00:42:26 Nov 04 2005 syslog
6 drwx 4096 12:47:52 Sep 04 2009 crypto_archive
64 -rwx 5623108 13:01:34 Sep 01 2009 asdm-522.bin
ciscoasa(config)# asdm image disk0:/asdm-522.bin
( 2 ) ciscoasa(config)#http 192.168.1.21 255.255.255.255 management
( where 192.168.1.21 is laptop IP address )
( 3 ) ciscoasa(config)#http server enable
( 4 ) https://192.168.1.1/admin ( to launch the ASDM page using IE , mozilla, and made sure Pop Up is enable and java is enable)
I got the error " Web page cannot display " HTTP 404 error.
Kindly look at my ASA5510 as per attach.
Panos Kampanakis Thu, 10/29/2009 - 09:51
  • Cisco Employee,
Can you ping the management interface from your pc?
MAke sure you also generate a key "crypto key generate rsa mod 1024".
Try https://192.168.1.1/
I hope it helps.
PK
Nay Myo Tun Fri, 10/30/2009 - 02:40
I even can telnet to the mgmt interface using 443.
Just tried "crypto key generate rsa mod 1024"." Same result.Thx.
mkharban Thu, 10/29/2009 - 11:33
Can we get the output of the following:
debug http 255
Java logs from the machine on which we try and access ASDM.
Manish
Nay Myo Tun Fri, 10/30/2009 - 02:37
Hi ,pls.take a look at the output.
ciscoasa# debug http 255
debug http enabled at level 255.
ciscoasa# HTTP: processing GET URL '/admin' from host 192.168.1.21
HTTP: redirecting to: /admin/public/index.html
HTTP: processing GET URL '/admin/public/index.html' from host 192.168.1.21
HTTP: authentication not required
HTTP: file not found: public/index.html
mkharban Fri, 10/30/2009 - 11:04
Please visit the following url and download asdm 6.2(1) version:
http://www.cisco.com/cgi-bin/apps/tblbld/tablebuild.pl/asa
Please upload this file to flash and enter the following command on the firewall:
asdm image flash:asdm-621.bin
For uploading the file to flash please follow the procedure as mentioned in the below given link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml#maintask2
This should fix the issue.
Manish
Nay Myo Tun Thu, 11/05/2009 - 19:51
Hi Gentlemen,
I ve manged to get the ASDM6.2 and uploaded it to the device and now able to access the device using the ASDM.
Really appreciate your professional advise.
HarveyTitanium Fri, 10/30/2009 - 10:56
I think you need ASDM version 6.x to connect with ASA version 8.x.
Pravin Phadte Mon, 11/02/2009 - 06:30
  • Silver, 250 points or more
You need to have Device Manager Version 6.1(5)
Upload this image of asdm and
config t
no asdm image disk0:/asdm-522.bin
asdm image disk0:/asdm-615.bin
Reload the Firewall.
Also see that your java is updated.
