Help with router specification
Oct 29th, 2009
Is there anybody out there that can tell me if this 2621xm has enough memory for me to upgrade it to 12.4 and it looks sound as a ccnp router. Here is the sh ver.... Thanks,
YCS_Bradford_John_Street_2621>show version
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(12a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 24-Sep-02 03:27 by pwade
Image text-base: 0x8000808C, data-base: 0x810CE560
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
YCS_Bradford_John_Street_2621XM uptime is 0 minutes
System image file is "flash:c2600-is-mz.122-12a.bin"
cisco 2621XM (MPC860P) processor (revision 0x100) with 60416K/5120K bytes of memory.
Processor board ID JAD070504FS (2623950720)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
YCS_Bradford_John_Street_2621>show diag
Slot 0:
C2621XM 2FE Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
PCB Serial Number : JAD070504FS (2623950720)
Part Number : 73-7754-02
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6D 41 01 00 C1 18 4A 41 44 30 37 30
0x10: 35 30 34 46 53 20 28 32 36 32 33 39 35 30 37 32
0x20: 30 29 82 49 1E 4A 02 04 00 81 00 00 00 00 42 41
0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
BRI S/T - 2186 WAN daughter card
Hardware revision 1.3 Board revision A0
Serial number 24041239 Part number 800-01833-03
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
0x20: 01 07 01 03 01 6E D7 17 50 07 29 03 00 00 00 00
0x30: 50 00 00 00 00 11 28 01 FF FF FF FF FF FF FF FF
YCS_Bradford_John_Street_2621>Gregg Hill
IAN WHITMORE Thu, 10/29/2009 - 14:00
I don't think so. You need at least 128k DRAM for the basic 12.4T IOS.
Ian
James Hawkins Fri, 10/30/2009 - 05:08
The 12.4 IP Base IOS image can run with 64MB DRAM.
This should provide the majority of features needed for the CCNP exams.
