Config wipe on dual supervisors
Oct 29th, 2009
  • Purple, 4500 points or more
Whats the easiest way to completely wipe the config off a 4500 with dual sup's . Write erase only seems to wipe the active nvram and when you reload it it goes to the backup which is normal. Just looking for a quick way to do both .
