Cisco Nexus Switches
Answered Question
Oct 29th, 2009
I am looking to deploy a Cisco 5100 series Nexus switch for 10Gbps.
I know the Nexus is supposed to work with the converged network adapter (for 10Gbps, FCoE, etc) but can it work without a CNA?
I want to put some 10Gbps passthrough modules in my Dell m1000 chassis and run cables directly to the Nexus switch.
I know the Nexus may be overkill for this solution but it is a step in the UCS solution for us.
Thoughts?
James
Correct Answer by inch about 7 years 3 months ago
Hi, you don't need any special drivers for "low latency" 10gb ethernet on a 5k.
for example, non-nexus 5k switch
PING 10.10.10.1 (10.10.10.1) 56(84) bytes of data.
64 bytes from 10.10.10.1: icmp_seq=1 ttl=255 time=0.530 ms
64 bytes from 10.10.10.1: icmp_seq=2 ttl=255 time=0.618 ms
and a nexus 5000 with a qlogic 8152
PING 172.16.78.3 (172.16.78.3) 56(84) bytes of data.
64 bytes from 172.16.78.3: icmp_seq=1 ttl=128 time=0.150 ms
64 bytes from 172.16.78.3: icmp_seq=2 ttl=128 time=0.134 ms
Your oracle rac cluster will fly!
Overall Rating: 5 (1 ratings)
jfraasch Thu, 10/29/2009 - 13:09
Do you have an idea if you need specific drives to run low-latency 10Gbps?
Will the 10Gbps from my 10Gbps pass-through modules automatically run at low latency or will it require something additional. This is for an Oracle Private Interconnection so latency is is utmost importance.
Thanks.
Jerry Ye Thu, 10/29/2009 - 13:30
Do you mean low-latency hard drive? I am not an expert on computer hardware and I am not sure.
For the Nexus 5000, delay will be minimal since it is doing cut-through.
jerry
Correct Answer
inch Sat, 10/31/2009 - 15:52
jfraasch Mon, 11/02/2009 - 06:43
I can't help but almost cry! That is exactly what I have been searching for.
Thank you!
