10-29-2009 05:59 AM - edited 03-15-2019 08:17 PM
Loading the VXML application from the Cisco Unified Communications Manager server (Publisher) to the voice gateway is one of the steps require to configure Mobile Voice Access. My question is; does VXML application exist on the CCM by default or do i need to download the application from Cisco site? Again, does the involve license? Finally, can anyone help me with configuration example for mobile voice access. I'm using h323 gateway with E1 connection to PSTN. I will appreciate your response.
10-29-2009 06:14 AM
Yes, you can download the VXML file from the Publisher.
Sample configuration for IOS Version 12.3 (13) and later:
http://
Sample configuration before IOS Version 12.3(12):
http://
See the link below for configuration steps:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmobmgr.html
Hope this helps.
Brandon
10-29-2009 07:05 AM
Thanks Brandon. You response is very helpful, but can you confirm that there is no license requirement for the VXML application?
10-29-2009 07:11 AM
No license requirement for the VXML app. Only license needed is DLUs for users who use mobility.
Hope this helps.
Brandon
10-29-2009 07:20 AM
Thank you very much. I will now get set for the implementation. Once again, thank you
