SMTP Traffic - Limit
Oct 29th, 2009
Hello
Can incoming and outgoing SMTP traffic for internet be restricted. SMTP Server is in DMZ.
Incoming smtp traffic host will be different
Outgoing smtp trafic host will be DMZServer 192.168.1.5
Restricting Bandwidth = 1MB
Overall Rating: 3 (1 ratings)
saquib.tandel Thu, 10/29/2009 - 07:24
Adding to it.
How to get total bandwidth used in last 24 hours for SMTP Traffic in/out.
Collin Clark Thu, 10/29/2009 - 07:43
  • Purple, 4500 points or more
You'll have to use Netflow or SNMP for that.
saquib.tandel Thu, 10/29/2009 - 07:52
Collin Thanks.
ASA 8.0 dont support netflow.
With SNMP I can get in/out bandwidth using tools (SolarWinds), not clear how to get SMTP traffic using SNMP.
Collin Clark Thu, 10/29/2009 - 08:25
Sorry, I was thinking just the interface, not a specific protocol. The only way that comes to mind is to check syslog. It shows the number of bytes during a TCP connection. Then you'll have to add them all up. Linux could be a great help here if that's an option. Some shell scripts could automate all that for you. There probably are some commercial products that do it, but I don't know of any.
