2950 lost IOS ??
Oct 29th, 2009
Something wrong with a 2950 when I boot it went to switch:
Then I tried this command
switch: flash_
Initializing Flash...
flashfs[0]: Checking block 4...bad block number (12)
flashfs[0]: erasing block 4...done.
flashfs[0]: Checking block 5...bad block number (13)
flashfs[0]: erasing block 5...done.
flashfs[0]: Checking block 6...bad block number (14)
Error message says" Bad block...", does that means the flash disk is broken? If not, how can i upload a IOS in this mode?
d_ferraro Thu, 10/29/2009 - 08:31
you could try to use xmodem via console to upload a new image(if there is room).
