Trunk-Group with FXO
Oct 29th, 2009
I have 6 FXO ports on a 2821 gateway and I had one of my POTS lines go down. The problem is it was the first one on my trunk groups priority list. It seems that when the line is dead it does not search to the next port in the trunk-group. Is there something I need to put in my config to go to the next FXO port? Also this gateway is a h323 device on a Call Manager. Here is snippet of my config
trunk group westel
max-calls voice 2
voice-port 0/0/0
trunk-group westel 2
caller-id enable
voice-port 0/0/1
trunk-group westel 1
caller-id enable
dial-peer voice 100 pots
trunkgroup westel 1
destination-pattern 9T
direct-inward-dial
Ken
