FWSM does'nt generate syslog message 111005
Oct 29th, 2009
To inform cisco works about configuration change I try to send syslog message 111005. Do to that I have change the logging level to lower level like error. This works for example with 111007 ( begin configuration ) but the FWSM doesn't send a message for 111005 also the level debugging. Software Version is 4.0(4). Is the a bug known ?`
Thanks for help
Steffen
matouses Sun, 11/22/2009 - 04:40
In the meantime we have Version 4.0.8 . The message doesn't generate on the FWSM.
Kureli Sankar Sun, 11/22/2009 - 06:30
I see this syslog getting printed in FWSM 2.3.5 code but not in 3.1.x, 3.2.x or in 4.0.x
FWSMconfig)# exit
%FWSM-5-111005: 127.0.0.51 end configuration: OK
Thanks for bringing it to our attention.
We will get this addressed on our side.
