Adding to Cluster Problem
Oct 29th, 2009
I have two c350's on separate networks with two firewalls between them.
When trying to add the second 350 am getting a time out error. When checking the logs it tries to connect to the cluster as anonymous and is refused access.
any ideas?????
Andrew Wurster Fri, 10/30/2009 - 22:21
can you review the following KB article please and verify all the steps?
http://tinyurl.com/pjmpwh
once you're done, if there's still trouble, you can include outputs from your 'system_logs' during the failed join.
